I think Sharen hit it right on the nose, a little more anguish on the face, but I really like the pic, especially the fact that you can't see the captured mans face, makes you wonder :)
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
It almost looks like the arm is "cut off" at the shoulder as opposed to being attached to someone. Are you keeping this as a straight poser render or will you be doing postwork in an image editing program? In addition to dirtying up the ground texture, you might add some rocks or try to create an uneven ground in Rhino and use that instead of the flat Poser ground. If you're doing post work, I'd render it with the prisoner but apply black over the face and shoulder, masking it so that it fades in from the shoulder to the face. That will also give it more depth. This is a challenging concept - how can one create the perception that the prisoner is being held "unjustly?" I look forward to seeing the final version!
"If you're doing post work..." I was going to see how much of it I could render just in Poser alone. "...the prisoner's arm should fade away." I used a box in poser as the base for the wall. The opening is via a transparency applied. Problem is you see the back (inside) surface of the wall. So I used a flat square prop with color set black and set it against the back (inside) wall. The cutoff of the arm is because of this. Maybe I'll just use a flat square prop for the wall instead and perhaps that will solve the "back (inside) wall" problem I have. Then I could actually create "space" inside and you'll see more of the prisoner. (c'mon 5 o'clock so I can go home and try it! ) I hadn't thought about creating the ground in Rhino. I was just thinking texture and bump map. Hmmmm. Got me thinking now!
Interesting picture. It has loads of potential. Here's my 2pence worth: Without adding more textures, I advise working on the lighting. If this is an evening rescue, strengthen the shadows of the background and use with a bit of "moonlight" or a torch for the light source. If this is a day time rescue, crank up the light so the shadows are noticably connected to the figures. Right now, everything seems to be floating in space. Either way, on your leading light, crank your "map size" dial up to at least 1024, though 2000-4000 is better. Then set your "shadow" dial to .25 to .5. Set all other lights to "no shadow".
The title refers to what really? Is this a man saving his lover, or a soldier his king. The hand has to tell the story. Chains maybee around the wrist, something like that. A nice soft glow from the interior my help depth. But that's post, right? Sorry. I would also like to see the finished product. This is not an easy image to make work. Keep at it. Good start. Q
Un coup de dés jamais n'abolira le
hazard
S Mallarmé
You might even consider modeling the wall (including the opening and the bars) and then a cell behind it (kind of like an open box on its side with the opening turned toward the window). That way you could put a backlight in the box to give you an outline of the prisoner without highlighting the prisoner's face.
Or may be you could....
"That's part of the fun isn't it!" said Bobasaur with a grin.
I don't see any drama in the picture at all. The man's face doesn't seem to show any emotion. "Unjustly Held" implies the picture should be more about the prisoner than the visitor. The visitor is looking away from the prisoner, almost as if he doesn't even know the prisoner is there. I'd suggest using a Point Of View that at least shows the prisoner's face partly through the bars. If you do things right you might still be able to the faces of both people. Or just showing the back of the visitor, but the prisoner's face somehow framed nearby. I agree with all the other comments about the scene being clean, needing different light as well. But none of those would make up for the lack of drama and emotion I've already mentioned.
You know, asp1vip, if you just want the hand there that's cool, it makes the image more interesting, more mysterious. Don't let us "know-it-alls" change your artistic vision of the image. I had a photo in mind, at the beginning of my career, I must have gone back and redone it 10 times over my career before I could get it just right. Sometimes, there's one or two like that, that challenge your skills, that resist the vision. But they teach you an awfull lot, they show you where you've been and where you're going. That's a precious tool, my friend. Render on and thanks for the opportunity to share in the creative process. Q
hazard
S Mallarmé
