You will not have a "rsr" or "png" thumbnail. I get around that by loading the figure, using the MOR file and then saving the Pose to the Pose library. Remember, you'll over-write your Pose file if you do this. If you're inventive, you can figure a way to do this! That's the quickie tutorial for the day.
Thank you Ron :) Very useful. The first time I see a morpose for Vicky with a working fbm "Muscular". In all my other morposes this did not work. Mazak
Wow, you're fast Ron. Thanks for making this mini-tutorial for MAT Pose Edit.
Mazak,
Possibly the reason why the full body morphs didn't work is that you used a pose file as a base. Poser can save also morph channels in pose files but not full body morphs. In a CR2 the full body morphs of course exist.
Here's how to add FBMs to a MOR file: Open the MOR in MAT Pose Edit, Import BODY actor from a CR2, Delete all pose channels and finally set the right values for the FBMs.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=736234
Thank you scourge, I found that already out (the long hard way, see link). With Rons explanations its now much easier. Full body morphs are created automatic in this example. MazakYes, I love MAT Pose Edit. You finally freed me to do what I wanted. I had to rush to get this tutorial done before leaving for work. I hadn't expected things to go so slowly. I did the tutorial "live," and didn't want to leave you hanging. Apparently I didn't leave out anything important. I'd guessed you'd set me straight if I had. Thanks!
