Fri, Jan 24, 4:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 4:20 pm)
Subject: Create a MOR File with MAT Pose Edit (Tutorial)
ronknights ( ) posted Fri, 28 June 2002 at 10:09 AM · edited Fri, 24 January 2025 at 11:44 AM
Always backup your work so you don't lose it! 1.) Load MAT Pose Edit 2.) Load Character
ronknights ( ) posted Fri, 28 June 2002 at 10:10 AM
3.) Say Yes, then wait till MAT Pose Edit finishes the next step.
ronknights ( ) posted Fri, 28 June 2002 at 10:28 AM
Delete all pose channels.
ronknights ( ) posted Fri, 28 June 2002 at 10:30 AM
Save as (Pose File) Remember always backup your work. Never take a chance of overwriting anything.
ronknights ( ) posted Fri, 28 June 2002 at 10:32 AM
Save as a Pose File. I'm being repetitive here, but in a hurry.
ronknights ( ) posted Fri, 28 June 2002 at 10:33 AM
You will not have a "rsr" or "png" thumbnail. I get around that by loading the figure, using the MOR file and then saving the Pose to the Pose library. Remember, you'll over-write your Pose file if you do this. If you're inventive, you can figure a way to do this! That's the quickie tutorial for the day. Message671414.jpg
Mazak ( ) posted Fri, 28 June 2002 at 3:28 PM
Thank you Ron :) Very useful. The first time I see a morpose for Vicky with a working fbm "Muscular". In all my other morposes this did not work. Mazak
Google+ Bodo Nittel
scourge ( ) posted Fri, 28 June 2002 at 5:53 PM
Wow, you're fast Ron. Thanks for making this mini-tutorial for MAT Pose Edit.
Mazak,
Possibly the reason why the full body morphs didn't work is that you used a pose file as a base. Poser can save also morph channels in pose files but not full body morphs. In a CR2 the full body morphs of course exist.
Here's how to add FBMs to a MOR file: Open the MOR in MAT Pose Edit, Import BODY actor from a CR2, Delete all pose channels and finally set the right values for the FBMs.
Mazak ( ) posted Fri, 28 June 2002 at 6:24 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=736234
Thank you scourge, I found that already out (the long hard way, see link). With Rons explanations its now much easier. Full body morphs are created automatic in this example. Mazak
Google+ Bodo Nittel
atom123 ( ) posted Fri, 28 June 2002 at 7:12 PM
feels good dont it ron. no more code editing ever! isnt this so awesome!
ronknights ( ) posted Fri, 28 June 2002 at 9:38 PM
Yes, I love MAT Pose Edit. You finally freed me to do what I wanted. I had to rush to get this tutorial done before leaving for work. I hadn't expected things to go so slowly. I did the tutorial "live," and didn't want to leave you hanging. Apparently I didn't leave out anything important. I'd guessed you'd set me straight if I had. Thanks!
ardvarc37 ( ) posted Sat, 29 June 2002 at 4:02 AM
Yo ronknights thank you for the tutorial! Alex
