Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Well, if you double click on the name (map size for example) then you can put in minimum and maximum values. Just increase your value and you can go higher than 1024.
There are a lot of things worse than dying, being afraid all the time would be one.
An often overlooked tip regarding lighting is use the shadow cam lite and zoom into your scene, ensuring the main element is centred in the shadow cam lite view. This way the shadow map is only being used on the parts you want it to be, and not having to cover a vast area. Go back to your real camera and render. You don't always need to up the size of the shadowmap either doing this, so saving resources too.
I'm working on an image that has a prominent shadow and the darn thing (shadow) has a case of the jaggies. There is only one light (a spotlight) in the image with shadows and I've played with all the dials til I can't see straight. Does anyone have a clue on how to correct this? I've got the anti-alias checked...that doesn't help. :-(
My idea of rebooting is kicking somebody in the butt twice!
