Thu, Jan 9, 5:05 PM CST
Subject: UV Problem With Object....How Can I Fix?
Krel ( ) posted Thu, 24 February 2000 at 6:39 AM ยท edited Tue, 07 January 2025 at 3:21 AM
I've been playing with the Anim8or 3D modelling freebie and created this prop. I would like to texture map it, so after converting to OBJ format and using UVMapper to create a map (saving the mapped prop), I get this when I render. Does anyone know how I can fix this? It looks like part of the objects vertices are backwards.... Krel
JeffH ( ) posted Thu, 24 February 2000 at 10:54 AM
Are you talking about the black area or the hole?
Krel ( ) posted Thu, 24 February 2000 at 3:36 PM
The black part is the problem.
JeffH ( ) posted Thu, 24 February 2000 at 3:43 PM
I've never seen the "black poly" problem so large before. From this angle it doesn't look like reversed normals though. I seem to remember one of the solutuions had to do with turning shadow-casting off for the prop. Does that area look "empty" or "see-thru" or does it just render black? -JH.
Krel ( ) posted Fri, 25 February 2000 at 6:01 AM
I'll try these suggestions......thanks for them.....the area just renders black it looks fine otherwise, no seethru sections. Krel
