Has anybody else encountered an error where it says a texture map can't be loaded, then it says Poser has caused an error in quicktime.qts after is closes or crashes? This happens to me way too often and usually ruins a rather extensive project, as well as corrupted half if not all of the rsr files of everything that's been loaded into the scene. Sure fixing those is easy, but when you have 10+ characters loaded it can get a little annoying remember where every little item is located inteh directories. I'd like to eliminate this altogether and be able to finish my projects.
