Tue, Jan 21, 11:57 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: DXF Models
Niles ( ) posted Sat, 06 July 2002 at 8:45 PM ยท edited Tue, 21 January 2025 at 9:38 PM
I need some help with this, I have only used a few DFX models and I have not had any problems with them ... till now. I downloaded several last night and am trying them now, with not much success. When I import them I get this and other messages. "3D facet data was found in BLOCKs. Object instancing is not supported, so olny one copy of each object will be created." Also I get message "This DXF file does not contain any 3D facet entity data and hence no model was imported." Any ideas guys and gals "hence" I have no clue. (had to use that word hince) :) Thanks Niles
nerd ( ) posted Sat, 06 July 2002 at 9:42 PM
Forum Moderator
Hate to say sorr, but sorry. You are going to need to run these models through a 3D modeling prog that speaks DFX. Posers DFX import is pretty limited and the model you are importing is too much for it. ngsmall02.gif
Grey_cat ( ) posted Sat, 06 July 2002 at 11:38 PM
DXF stands for Drawing eXchange Format. It's a file format intended to be used to transfer drawing files between drafting packages. It is not a 3d file format, though it can have 3d information in it. You really need to know what the file was intended to be used for.
