Aleks- If your setup is working well, then don't install the 4-in-1 drivers. If, on the other hand, you're having problems, say for instance stability issues, or you can't enable DMA for your CD/DVD etc, then you try the 4-in-1. Generally speaking, if it ain't broke don't fix it. Oh, and make sure you're using a VIA chipset, not all athlon mother boards do. Regards- Lemurtek
Hi aleks, If I remember correctly, the last time I DID install the VIA 4-in-1 drivers, but after reading somewhere that there may be problems installing them in "Turbo" mode, I chose "Standard" mode instead. "Standard" or "Normal" mode is supposed to give you more stability over speed...so far no problems. (fingers crossed!) Dave :-)
was a hard job and making xp work together with the new hardware without installing all new took me 2 hours. but now i can use the new Athlon xp in future :-)
