Tue, Feb 18, 7:29 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: Wireframe Renders Possible??
rodpanther ( ) posted Tue, 09 July 2002 at 10:37 AM ยท edited Tue, 18 February 2025 at 7:29 AM
Hi, I know poser has various display settings like wireframe, solid, filled solid, full etc and was wondering is it possible to render using these? Ie if i display a model in wireframe can i render it as wireframe? I looked in the render options and couldnt find anything to render with current display settings. What i am doing is just taking a screen grab of the poser window and pasteing it into a paint package but alas that doesnt help when i want to make the wireframe model transparent so a background image will show through it. I usually save the rendered images from poser as tiffs then select the alpha channel and remove the background that way but with a screen grab this is not possible. Thank you
Dolphin ( ) posted Tue, 09 July 2002 at 10:44 AM
I can think of a way.. but not sure if it's practical.. if you have the template for the character you want to render, you could do a little transmap, use the template as the texture(coloured to your desire).. ? I'm new so I'm not sure.. but that's how I'd do it.. and therefore it's probably wrongL cheerz Dolph.
JeffH ( ) posted Tue, 09 July 2002 at 10:54 AM
Use the Make Movie feature and render to sequenced image files (tif) using display settings and antialias. Set your display to wireframe etc..
rodpanther ( ) posted Tue, 09 July 2002 at 11:02 AM
Thanks to all that replied I just figured if i select wireframe display and then export the image as is before normally rendering, it works and saves as a tiff!!! lol Simple even for the likes of me :)
JeffH ( ) posted Tue, 09 July 2002 at 11:41 AM
Yes, but making a large render is difficult that way.
rodpanther ( ) posted Tue, 09 July 2002 at 12:09 PM
I know Jeff but i was just making a new heading for my website and here is a test i did.
Hope you like :)
Hiram ( ) posted Tue, 09 July 2002 at 12:47 PM
Get your image the way you want it on screen, then go to Render> Antialias Document, et viol Good luck.
Scarab ( ) posted Tue, 09 July 2002 at 1:04 PM
Just set up your wireframe display and then go to the "render" pulldown and select "antialias this window" (or however it's worded. That will produce a sharp version of the wireframe. Scarab
Hiram ( ) posted Wed, 10 July 2002 at 4:20 AM
Is there an echo in here? Is there an echo in here? ; )
Scarab ( ) posted Wed, 10 July 2002 at 6:09 PM
Great minds think alike... Scarab
