Thu, Feb 20, 11:23 AM CST
Forum Moderators: RedPhantom
Subject: Grouping tool question
Raddar ( ) posted Tue, 09 July 2002 at 4:26 PM ยท edited Wed, 08 January 2025 at 4:47 PM
I am using the grouping tool on the MilBabies head. I am only trying to group out a mask but I keep getting pieces in the group that I dont want, ie. the teeth, inside the mouth, inside the nostrils, inside the ears, the back of the eyeballs, etc. etc. And the most frustrating are those @*#&%%^$ upper eyebrows. I cant for the life of me seem to get the skin under them selected without getting them along with it. What are those stupid things for anyway since they are most always transparent and you see right through them. Anyway any tips on grouping would be very helpfull. Thanks.
shadowcat ( ) posted Tue, 09 July 2002 at 5:09 PM
the upper eyebrows are supposed to be used with a transmap for a more realistic look. now to your main question (I'll use vicky to illistrate) 1. With the head selected go to grouping area & select new group and click ok when prompted. (so far so good you've probably already gone this far)
shadowcat ( ) posted Tue, 09 July 2002 at 5:16 PM
2. now locate the button "include material" select Skinhead from the pull down menu. repeat for Eyebrows, Lips & Nostrils (lips & nostrils optional, depending on if they will be included in the mask)
shadowcat ( ) posted Tue, 09 July 2002 at 5:21 PM
3. now create a new prop from this. you now have somthng to work with. no upper brow, no eyes & no lashes.
shadowcat ( ) posted Tue, 09 July 2002 at 5:25 PM
  1. click remove all & start selecting what you want for yor mask. when you select sections you dont want, click "invert group" select the error, then invert again. good luck
Spanki ( ) posted Tue, 09 July 2002 at 8:04 PM
"when you select sections you dont want, click "invert group" select the error, then invert again." ... Or just hold down the ctrl key (alt key? one of those) and select... that de-selects.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
shadowcat ( ) posted Wed, 10 July 2002 at 2:45 AM
Oooo, a hotkey, yippee. I've been doing it the hard way
Raddar ( ) posted Thu, 11 July 2002 at 5:08 PM
Shadowcat, thanks a million, you have brought my frustration level back down to a managable level. Those tips work great. Thanks again.
