Forum Moderators: Wolfenshire, Deenamic Forum Coordinators: Anim8dtoon
Photoshop F.A.Q (Last Updated: 2024 Sep 19 10:49 pm)
Select the layer you want to make transparent in the layers palette. Click in the upper right-hand corner of the palette where it says "Opacity" and a slider will appear. Drag the slider to make the layer more or less opaque as desired. Use layer masks with a gradient fill applied to create effects where an image fades into another one. Gromit Dhahran, Saudi Arabia
Also if you do your renders as .tiff's you can cut the extra background image away from the figure by selecting the alpha channel, inverting the selection and then deleting the background. With that you can move figures around in the scene. Add some drop or perspective shadows to add to the illusion. -Trav
If you're compositing renders made against a black or white background into a background image, you may find that it adds to the photorealism if you use Layers, Matting, Remove Black Matte or Remove White Matte. This will clip off the remaining background pixels from your figure. The other thing I do when I want to add shadows is to copy the layer the figure is on, fill the copy with black, move it so the layer is below the figure's layer, use the transform tools to distort it so it looks like it's on the ground plane or whatever, do a Gaussian blur to soften it, reduce the opacity to around 50% or whatever looks good, and it makes a pretty good shadow as long as the light is coming from behind the viewer, so the shadow extends into the picture. If I need a shadow to be in a different direction, I usually do a separate render from a camera position pointing from the direction of the light source. Then I do the same operation, filling it with black, etc. to create a shadow that appears to be geometrically correct. Gromit
Okay, in Photoshop I figure there's gotta be some kind of tool that lets me make an image look transparent?? You know, like see-through?? So's I can put two images on a rendering and have the second image kinda behind the first, but the first image transparent enough to let me see the second image through it???? Anyone here have the know how on this?? I have seen it done, so please do tell?? ~3D ;-)
