Thu, Nov 14, 12:38 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
Subject: PhiFactory Error
shdwcstr ( ) posted Sun, 27 February 2000 at 1:36 AM ยท edited Thu, 14 November 2024 at 2:27 AM
This error occurred while loading the Female Nude P4 character.
bushi ( ) posted Sun, 27 February 2000 at 2:13 AM
OK, this looks like the same thing that is giving WyrWolf a problem. I just tried it here and got the same error using the 'Load' button. If you want to convert a .cr2 to a .phi use the 'Phi From Cr2' button. It has a file locate dialog so you can tell it which .cr2 to use. The load button is JUST for .phi files as it pulls in (or at least tries to pull in) the entire file. This error is just saying that the file is to big for it to load. Thanks for the feedback! I'll make that clearer in the next version.
wyrwulf ( ) posted Sun, 27 February 2000 at 10:29 AM
This is the same problem I had. I tried Phi From Cr2 with the Fem Nude P4, and it loaded fine.
Anthony Appleyard ( ) posted Sun, 27 February 2000 at 3:03 PM
I just called PhiFactory on two .CR2 files that each contained several models (my "frogman with rebreather" and "scuba diver" models); the resulting .PHI file was only for the first model in the .CR2 file (the "man in diving suit"); but at the end of the .PHI file were all the IK chains for all the models in the file including e.g. his breathing set (which is a separate model).
bushi ( ) posted Sun, 27 February 2000 at 3:24 PM
It's not a fault, it's a feature! ;-) Yes, I'm aware of this. I tried it with one of my own multi-figure .cr2s and had a similiar result. On this version I was concentrating on the standard Poser .cr2 formats so multple figure .cr2 will be added to a later release. Thanks for your input!
Anthony Appleyard ( ) posted Mon, 28 February 2000 at 2:25 AM
It would be very useful if PhiFactory had a help. A help as a .TXT file would be better than no help at all. E.g. what exactly do the buttons "child" and "add" do?
Anthony Appleyard ( ) posted Mon, 28 February 2000 at 3:11 AM
It would be useful, if PhiFactory finds that the Cr2 filew contains more than one figure, it could translate each figure into a separate PHI, and then have a menu to choose which of these PHI's to display at the time.
