Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
OK, this looks like the same thing that is giving WyrWolf a problem. I just tried it here and got the same error using the 'Load' button. If you want to convert a .cr2 to a .phi use the 'Phi From Cr2' button. It has a file locate dialog so you can tell it which .cr2 to use. The load button is JUST for .phi files as it pulls in (or at least tries to pull in) the entire file. This error is just saying that the file is to big for it to load. Thanks for the feedback! I'll make that clearer in the next version.
I just called PhiFactory on two .CR2 files that each contained several models (my "frogman with rebreather" and "scuba diver" models); the resulting .PHI file was only for the first model in the .CR2 file (the "man in diving suit"); but at the end of the .PHI file were all the IK chains for all the models in the file including e.g. his breathing set (which is a separate model).
