Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
You can do this with Poser alone, by exporting a morphed body part as a Wavefront .obj file, loading the second figure into Poser, selecting that body part, and selecting Add Morph Target from the Object menu.
Remember, morphs can only be exchanged between characters that share the same mesh (for instance, Victoria to Victoria, or Posette to Posette). Stephanie and Michael were built from the same mesh, so many of their morph targets can be exchanged.
However, it's easier to use a utility like Mason's Morph Manager 4.0, available in Free Stuff, to transfer morph targets directly from one character's CR2 file to another.
Bonjorno Ladies and Germs:
Once again I ask for your help and your knowledge to come once more to the aid of this your humble servant(fancy talk for help me I'm a moron).
Anyway,I need your help with the following.... I need to know if it is possible to extract a morph target form one figure and use it on another with out having to go through
any other type of utility or application and doing it directly from poser?
PS: if I have to use a utility or application which one should I use?
Thanks.
Ask me a question, and I'll give you an answer.
