Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
Okay, gulps down first coffee of the morning.
I'm running an Athlon 1.33ghz with 1G ram but on windows ME. 16M Voodoo3 graphics card. I've had problems before with rendering mulitiple figures causing the programme to crash but rebooting has always sorted it out. Not with Michael though.
Poser will render fine with Michael plus props and other figures, it's only when I put another Daz figure in the scene that I get the problem.
By the way, it's Michael 2 with Hi-res texture.
'Athlon 1.33ghz with 1G ram but on windows ME' and there could be your problem... Win9x (of which ME is part) does not support ram over 256mb :( bascially it's not using it at all.. for that much ram you need win2k or winXp... interesting to note - M$ still support the older 98Se but have effectively dumped ME... Kai
Actually I know remember that I had the same problem with an almost identical configuration ME/256MB, Vicky and Hi-Res hair. The temporary solution was to reduce the resolution of the textures which seemed to be the cause of the problem. Most folk who have upgraded to XP seem to have found a positive improvement. Bill
AAAARGH! I'm running P4.03. If I load Daz's Michael as a single figure he will render fine. If I put him with any other figures - Vicky for example - then the whole thing crashes when I hit the render button. Is it me, Michael, Poser or what?
Jack
