Mon, Jan 6, 10:23 PM CST
Subject: sharkey's Great White (Any troubles loading it?)
TalmidBen ( ) posted Sat, 13 July 2002 at 11:19 PM ยท edited Mon, 06 January 2025 at 10:17 PM
Hey friends, I've downloaded Sharkeys Great White (Thanks sharkey!!!), but it won't load correctly, displaying an error, has anyone else encounted this, and fixed it? I can load the static .obj model, and apply the map, and it looks great. But any known fixes? Thanks, ben
MarianneR ( ) posted Sun, 14 July 2002 at 3:51 AM
Where did you put the obj-file? If you didn't edit the cr2-file it must be in :Runtime:libraries:character:Animals: or Poser won't find it.
igohigh ( ) posted Sun, 14 July 2002 at 11:00 AM
It loads fine for me, what error do you get?
robert.sharkey ( ) posted Sun, 14 July 2002 at 1:59 PM
Did you converted the BumpMap to a real Poser-BumpMap as displayd in the readme ? I suggest this can eliminate the error-message. Below is the exact path where the object had to be. Runtime/Geometries/sharkeyStuff/WhiteShark/WhiteShark.obj The CR2-File targets exactly to this path. All files will be placed automatically on the correct place when using WinZip's extraction-function. In wish this info helps. SHARKEY
TalmidBen ( ) posted Sun, 14 July 2002 at 2:26 PM
Hey Sharkey! Yes, I converted the bump map and everything. This is the exact error message I get: Cannot open RuntimeGeometriessharkeyStuffWhiteShark WhiteShark.obj Cannot open resource file RuntimeGeometriessharkeyStuffWhiteShark WhiteShark.obj Also, Sharkey, are you sure anyone can sell images made with the free shark? I mean, it seems to good to be true! The shark is AWESOME. Ben
robert.sharkey ( ) posted Sun, 14 July 2002 at 3:02 PM
Looks like a corrupted RSR-File in the Geometries-Folder. Try to delete this RSR-File which sits in the same folder like the Object-file. Poser generates this file automatically from the object-file and from then on uses this RSR-file instead of the object-file. Sometimes it can happen that this file becomes corrupted. Yes, the Shark can be used for commercial images. Glad you like it. SHARKEY
TheWanderer ( ) posted Sun, 14 July 2002 at 5:57 PM
Hi Yes I had the same problem do as sharky says delete rsr and it'll work fine. I got one hell of a shock when I first opened it! 12:00 at night and it pops up on my screen teeth first I nearly fell out of my chair:-() see you later Dave btw try toucan for some realy good shark props (different specis)
TalmidBen ( ) posted Sun, 14 July 2002 at 6:52 PM
YEee-haw!!! It WORKED! Thanks so much Sharkey!
