Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 06 7:01 am)
Did you converted the BumpMap to a real Poser-BumpMap as displayd in the readme ? I suggest this can eliminate the error-message. Below is the exact path where the object had to be. Runtime/Geometries/sharkeyStuff/WhiteShark/WhiteShark.obj The CR2-File targets exactly to this path. All files will be placed automatically on the correct place when using WinZip's extraction-function. In wish this info helps. SHARKEY
Hey Sharkey! Yes, I converted the bump map and everything. This is the exact error message I get: Cannot open RuntimeGeometriessharkeyStuffWhiteShark WhiteShark.obj Cannot open resource file RuntimeGeometriessharkeyStuffWhiteShark WhiteShark.obj Also, Sharkey, are you sure anyone can sell images made with the free shark? I mean, it seems to good to be true! The shark is AWESOME. Ben
Looks like a corrupted RSR-File in the Geometries-Folder. Try to delete this RSR-File which sits in the same folder like the Object-file. Poser generates this file automatically from the object-file and from then on uses this RSR-file instead of the object-file. Sometimes it can happen that this file becomes corrupted. Yes, the Shark can be used for commercial images. Glad you like it. SHARKEY
Hi Yes I had the same problem do as sharky says delete rsr and it'll work fine. I got one hell of a shock when I first opened it! 12:00 at night and it pops up on my screen teeth first I nearly fell out of my chair:-() see you later Dave btw try toucan for some realy good shark props (different specis)
