Sun, Dec 1, 12:45 AM CST
Subject: How to turn off the lines behind the models?
StarGate ( ) posted Fri, 19 July 2002 at 11:54 AM ยท edited Sun, 01 December 2024 at 12:43 AM
How to turn off the lines behind the lt wire models as seen in this image - they are the green lines. TIA
c1rcle ( ) posted Fri, 19 July 2002 at 12:02 PM
did you have the models selected when you did this? great looking picture by the way. the lines I think are the orientation lines, not sure if that's the right name, but you only see them while the model is selected. Rob
Valandar ( ) posted Fri, 19 July 2002 at 12:17 PM
I beleive "Show Origin" was checked for these parts. Select them, and uncheck "Show origin"
Remember, kids! Napalm is Nature's Toothpaste!
Patricia ( ) posted Fri, 19 July 2002 at 12:24 PM
Beautiful image! Except for her foot being stuck in that sphere....G
StarGate ( ) posted Fri, 19 July 2002 at 1:45 PM
OK I can not find 1 how to unslect the objects 2 can not find show origin (so I can un-select it
Patricia - is the foot better :-)
Allen9 ( ) posted Fri, 19 July 2002 at 1:49 PM
Select ONE object. Then go up to the menu at the top and select OBJECT, then PROPERTIES. In the properties screen there is an entry for "Show Origin" - remove the checkmark in that box and click OK, and the green lines for that object will disappear. Repeat as needed for other objects.
StarGate ( ) posted Fri, 19 July 2002 at 2:09 PM
Thanks Allen9 two more questions 1 I got the the props to un-show the origin - but how do I select the full body so I can un-check show origin 2 when I imported the image at normal size it is big can I re-size the document window (the window that displays the image and the models) without distoring the image ratio?
StarGate ( ) posted Fri, 19 July 2002 at 2:59 PM
OK I figured out how to unselect the full figure
