Heya, select the head for the figure and then got to object, lock object, then apply the pose. Lock any body part you do not want a pose to change. Unlock when done. Don't use the lock figure unless you want to lock the entire figure, which means no pose or changes can be applied until you unlock it.
Look do it the easy way. 1.) Create a Face Library for the character whose face you want to save. 2.) Add that face to the library. 3.) If you lose that face, just click on the Face icon in the library and bring it back. I routinely create Face Libraries for many characters. Those include character and facial expressions. I always save the default face to that library first. Then I can always bring it back.
If you've got a bunch of poses that include the expression morphs (very bad technique) and you don't want to edit them all, you can create a set of your own expressions that are correctly limited. - save them as face files, but select sub-set and uncheck all the face-shaping morphs (tedious) - or you can delete the face-shaping morphs more quickly in a text editor As thebert suggested, you then can apply an expression after applying a pose and/or character morph, which won't be changed by the expression. That's how all my XprssnMagics are set up - plus as separate eye and mouth expressions for more combinations :-) Elisa/gryffnn
The sure way is to filter the poses through a figure with absolutely no morphs to begin with. Using a copy of your figure cr2, delete all of the morphs. (The quick way to do this: change the extension to pz2 open this in MM4 Other options = delete all morphs save the pz2 change the extension back to cr2.) Apply the pose to this figure and save the pose back to the library. ( If you like the previous rsr, give it a slightly different name, and using your file manager, delete the old pz2 and the new rsr and make the name of the new pz2 match the old rsr.) The bare bones figure is peachy keen for developing and saving your own poses. And it does not matter if you forget to tell it not to save morph channels, or you have Poser 3, which did not offer this option. These clean poses are safe with any character.
I created a face which includes subtleties in the arch of the eyebrow, eyelid position, etc. But as soon as I click on a preset pose it changes all my facial expressions to the poses preset facial expressions. How can I use the preset poses without it changing my character's facial expression?
