heyas; remember, the sketch renderer doesn't do transparency. it will always outline items that are supposed to be 'invisible.' the black outlines around the eyes are most likely the corneas. not sure why it is doing that in the mouth and behind the body (unless the wings are transparent, and the sketcher is being annoying). you can turn off outlines alltogether, in the sketch renderer. i can't remember exactly where; i think it has it's own 'tab'. there's 'background,' 'foreground,' and 'outline,' i believe. if not, there's a thickness and head/tail length controlls for the outlines on the foreground settings. also please remember to check the nudity flag when you have an unclothed figure in your image. thanks!
From what I've been able to tell sketch render works sorta like a filter in Photoshop. Changing your display settings before you sketch render will change the outcome of the sketch render. Did you have the eye selected when you did the render? In any event try different display settings with the same sketch render setting - you may find a oombo you like
Actually, the eyeballs and teeth are outlined because the head is the selected object. The sketch renderer is "rendering" the red, outlined lines as if they were part of the image. Before you render, make sure to move the mouse until no body part is selected and then do the sketch-render. This may get tricky since moving your mouse over the main window will cause the body part to be highlighted. The solution is to move the mouse off the main window, and hit "Alt-R" (Render menu) and "S" (Sketch Render option). (If you use a Mac, I don't think there is a way to access the menu using the keyboard .) --John
VanishingPoint... Advanced 3D Modeling Solutions
Attached Link: http://www.db70.com/bp/
I don't know what your sketch settings are here, but in the sketch designer, select EDGE and set the DENSITY to 0. That often gets rid of unwanted lines. You know they are EDGE lines if they are the last thing drawn in the preview window.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
