Bryce F.A.Q (Last Updated: 2025 Feb 02 12:16 am)
Bryce on XP is a bit funny about its windows. Most of the time on XP you can't access the task bar with Bryce maximised, even though the task bar might be visible on-screen. You need to minimise first. Until you get used to it, this can lead to horror <:0 when you try to click on another app in the middle of a render but Bryce decides you've actually clicked on-screen and stops the render and you don't realise! Rest assured Zhann that you WILL have all the options there somewhere!
Hi, I just installed Bryce5 and already I've run into a problem. Although the manual says there are file menu options to set initially,i.e., create a document, resolution, positioning the camera etc.,no file men shows in the app. After reading the 'readme' one of the problems they state is no file options will show in WinNT (it doesn't do something) however I have WinXP which I understand is based on NT. Does anyone know a work-around for this?
Bryce Forum Coordinator....
