Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 9:20 pm)
I believe Zygote has one for sale, and I think I've seen one on someone's site, but I've forgotten whose is is. Just one little point, however, if you're planning on using these two objects together: polar bears are in the northern hemisphere and penguins in the southern hemisphere, and they're never together. They live at opposite ends of the Earth. Just a little FYI, so you can avoid negative comments from others if you post it. Melanie
Dedicated Digital, http://www.dedicateddigital.com/ had a baby polar bear as a freebie. You might be able to get it from them, but their license is similar to Zygote's, so the models can't be shared. Zygote sells a bear as well as a penguin. You should be able to make a texture map to turn the brown bear into a polar bear.
hi all. i have been looking around a lot and cant find a penguin or polar bear model to use in a scene can anyone help??? ...i would rather not ahve to take the time to make one. thanks
