Wed, Nov 27, 10:14 AM CST
Subject: Problem with clothing !!!!
axe3677 ( ) posted Wed, 31 July 2002 at 8:48 PM ยท edited Wed, 27 November 2024 at 10:12 AM
I have some problem with all clothing i try to put on my character, the skin of the character go out of the clothing, any conforming ones... To adjust i have to change all the settings of the different part of cloth but that not run very good... Have you a little tips to correctly use the setting, or there is a problem with my computer or poser (i think is a problem with my computer but...) ?
queri ( ) posted Wed, 31 July 2002 at 9:17 PM
Can you give us an example, maybe with a screenshot. Poke through is a general problem with a lot of conforming clothing. Sometimes you have to make some parts of the body invisible-- the legs in particular in pants, also the feet in boots. Sometimes there's just no fix beyond postwork and the cloning brush and smudge tool. All conforming clothing needs to be with the character it was made for and all of them suffer with extreme poses--and that can include some simple sitting poses as extreme. If you show us what you're having probs with, I'm sure we can help, and I'm pretty sure it isn't your computer. Emily
axe3677 ( ) posted Wed, 31 July 2002 at 10:02 PM
Ok, i do some fast render with the problem... Thanx for your (future) help. ;o) Sylvia
axe3677 ( ) posted Thu, 01 August 2002 at 5:21 AM
Here is the screen shoot of the problem... The only thing hurt me is, before when i use the clothing, i dont have these problems (look at my gallery) and now argh !!!!
queri ( ) posted Thu, 01 August 2002 at 10:50 AM
Ok, is this Vicki and or Stephanie with the catsuit? And, is it the standard default body? I'll grant you it looks pretty bad. Emily
axe3677 ( ) posted Sat, 03 August 2002 at 5:57 AM
Is the victoria 2 standard default body, with default catsuit for victoria...
queri ( ) posted Sat, 03 August 2002 at 2:08 PM
My first take is the breasts look too low for default, like it is a custom body-- but I believe you. This is the kind of thing I've had happen a million times with custom bodies but never with default. I think you could probably get it to fit a bit better with scaling the hip areas larger, but . . . really? I'd reinstall Vicki and the clothing pack and try it again. You have a texture on the model-- did you use a Mor file for the character of the model? That could have changed the proportions. Emily
queri ( ) posted Sat, 03 August 2002 at 2:11 PM
Another thing to try. Load Vicki without textures-- straight out of the box in the default positon and load and conform the catsuit to her then. If that fits, you know it's a problem with the Mat for the texture including changes to the body, if it doesn't fit, you need someone more experienced than me. What texture is it? Emily
axe3677 ( ) posted Sat, 03 August 2002 at 2:39 PM
I think you're right... the body present some modification than a original... The textures are from alyssa (Shredboy) I try your solution... I tell you if it work
