Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 05 11:51 pm)
Attached Link: http://mine.site.ne.jp/dld/
If this is Vicky 1 lo res then you can also just spawn a morph target, export it making sure only the last option(export as morph target) is checked and run it through Morph Squeeze. You'll be left with an .obj that is ok to distribute. If you've used only morphs that come with the figure or it's Vicky 2 lo res then just save as a fc2 file and distribute that, there's no need to distribute a whole cr2 just for a face morph. There have been several lo res vicky characters released: Minerva has a complete character with texture and hair at Digital Love Doll (check under freestuff, character MT) called Yumi http://mine.site.ne.jp/dld/ Taruru has Serena here http://isweb34.infoseek.co.jp/photo/tarurud/ Also at d!works you'll find Ai http://www.valley.ne.jp/~okaniwa/cg/down.htm http://www.valley.ne.jp/~okaniwa/cg/dworks.htm I'm sure there are others but that's all I can think of now. Look around, check their links, you won't be disappointed! Also keep in mind that any fc2 files that work for Vicky will also work for Vicky lo res as long as it's the same version i.e. Vicky - Vicky lo res, Vicky2 - Vicky2 lo res.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
