Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
in the cr2 for the robe, replace all instances (there should be 2) of the old obj with the new object and then save the cr2 under a new name as well. if you have changed the materials, you need to edit these in the cr2 as well. then bring the robe in from the library using your new cr2 instead of importing the new object. If you havent edited the object in any way except for materials, it should work fine.
Ok...another newbie question. I opened an object in UV Mapper (not pro) and hit "new uv" and selected "Planar" for one of the parts of the object. (because in the original map, I only had one side to the object, so whatever I painted on the front, would also appear on the back). Now my question is, how do I get this map applied to the object? (told ya it was a newbie question:) Rawn
