Your image looks great.
If you want to print your image here is a few guidelines.
First, you should find a high quality printer! ;)
make sure you render your image at 300 DPI
This chart should give you an idea of the size of the printed image and the actual image size you have to render.
Inches Pixels 2x3 600 x 900 4x6 1200 x 1800 5x7 1500 X 2100 8x10 2400 X 3000Also, I would crank up the antialiasing to the highest level.to make sure you don't get an jagged edges on the paper.
I hope that helps.
Keep up the good work,
Ozan
Attached Link: http://www.renderosity.com/%7Evue/archtips.html
Nice work. And follow Horno's tip!!:-) For all printing questions see in our ARCHTIPS (address above) GuittaYep to her butt sticking out...a postwork fix is probably the best and easiest solution for that though. One more minor thing...I would rotate some of the plants on the far shore so they aren't all oriented the same way. It would give it a more natural look since you are working with identical plants.
hi gang, thanks for all the replys.... but as for now I'll be off of vue for sometime, I was trying to cranck the antialiesing but it didn't work, I need to produce images in high res for printing and vue will only due it with the standard anti alias and that's not good enough, maybe it's my old copy but right now I don't really have the time to do it...anyhow thanks a lot for the tips and answers and I'm glad you guys like the images.... and rimkopf msg me in private so we can see about the tree.... thanks guys.... yours vince
