Tue, Nov 26, 4:20 PM CST
Subject: PZ3 file problems
Samurai0 ( ) posted Mon, 05 August 2002 at 10:56 PM ยท edited Tue, 26 November 2024 at 2:33 PM
Hi, I have Poser v4 installed. (not with propack). So, my pc crashes (directx problem) and the 'poser.rsr' file is corrupt. I can't open Poser at all. I then reinstall Poser 4. Now none of my PZ3 files I saved before the re-install have the proper figures. It's like the 'body' is invisible, but replaced by a piece of clothing. I can still select any body part from the 'invisible' BODY, but I still can;t see it. So, I unarchive a good copy of the PZ3 files over the bad?-PZ3 files, but all I see is the hair and clothing, and no visible BODY. And yes... the "visible" property setting is checked. I am guessing something got changed from the re-install, that makes Poser not able to read any PZ3 files properly and replaces the BODY with an article of clothing. I can build new people from the "figures","props",etc. But, when I try to reopen the recently saved PZ3 files now, all I see is a dopey dress subsuituted for the BODY. Help Please S0
Shiby561 ( ) posted Mon, 05 August 2002 at 11:20 PM
Im not an expert but id recommend deleting it all with no backups and reinstalling completely. sry.
Samurai0 ( ) posted Mon, 05 August 2002 at 11:28 PM
Thanks. But I need more opinions and options. I have about 200-300 custom sets installed, and that means I'd have to reinstall them too. Is there any easier and faster way to install these custom things again? Later S0
dkirk ( ) posted Mon, 05 August 2002 at 11:40 PM
Your .obj files might not be in the right place anymore. You can open the .cr2 of the bodies or props which are missing (right-click/open with... - I usually use Wordpad) and look for a line which reads something like, "Geometries:MilWom: ..." and make sure it matches what's in your Poser 'Geometries' folders. Usually when I load an item and it doesn't appear but is listed, I've found that the .obj file is missing or is incorrectly mentioned in the .cr2 file. Hope this helps.
Samurai0 ( ) posted Mon, 05 August 2002 at 11:49 PM
Hmmmmmm.... Hmmmmmmmm. I'll check this. Now how does this sort of thing happen? Was it he reinstall or a glitch in poser? I think Poser pretty much works on a "modular" system - being able to interchange files without much hassle. Some of these PZ3 files were DL'ed from the Net, and opened okay before. I'll check the CR2/OBJ thing. Anymore suggestions? S0
bloodsong ( ) posted Tue, 06 August 2002 at 4:33 PM
heyas; let me get this straight.... you trashed your poser.rsr for whatever reason. so then you re-installed poser, right? and tried to open a pz3 you had from before. and they don't work. after you re-installed your poser, did you patch it? if you got it before it went to curious labs, it needs a patch. (it should be 4.03) after you re-installed your poser, did you backup and write-protect the poser.rsr? this would be helpful for avoiding the problem in the future ;) now, if all your pz3s use the same figures (ie the p4nw or whatever) or same group of figures, then your problem is easily explained. i hope. try going into the geometries directory under runtime and deleting all the rsr files you find in there. then open the pz3's again. if that doesn't fix them, i think it's safe to say, you're screwt. :/
