Thu, Nov 28, 12:47 PM CST
Subject: help please!
lj456 ( ) posted Fri, 09 August 2002 at 10:55 AM · edited Thu, 28 November 2024 at 12:42 PM
the elvation palette under the terrain editor won't show up and i need it for like every tutorial that i have come across. i just started using bryce so if someone try to help i would appreciate it.
tuttle ( ) posted Fri, 09 August 2002 at 12:02 PM
What happens when you click the tab? Is the tab there? Are the other tabs there and do they work?
lj456 ( ) posted Fri, 09 August 2002 at 2:30 PM
Well there is an elevation, pictures, and one more tab that i can't remember off the top of my head but when i click the two tabs BESIDES the elvation they work..but when i click the elevation tab no options pop up like the other two...
tuttle ( ) posted Fri, 09 August 2002 at 2:41 PM
That's a bit weird. The elevation tab should be the default one when you go in -- i.e. the options should just be there (like fractal, noise, erosion, etc.) What is there in place of the options? Just blank space? Very odd, unless I'm thinking of the wrong thing.
lj456 ( ) posted Fri, 09 August 2002 at 5:12 PM
nope your right where all those options you named are SUPPOSED to be there is just blank space..
madmax_br5 ( ) posted Fri, 09 August 2002 at 10:16 PM
try re-installing. Copy all of your presets and stuff and stick them in another folder. The just un and re-install bryce.
tuttle ( ) posted Sat, 10 August 2002 at 5:48 AM
Yes, try a re-install. Something has gone wrong here. Let us know if it fixes it.
lj456 ( ) posted Sat, 10 August 2002 at 10:46 AM
ok thanks for your help guys i'll try it out and let you know how it turns out tomorrow because m not at home. but thanks again i appreciate it. =)
