I had this problem once - And as far as I can remember it I deleted (to RecycleBin) some file that were only on Poser3 - Not Existed on Poser4 any more (I Think). Delete the files that have 640x480 or 800x600 the same file with your Screen Resulution and try to make poser create a new one (Also need to delete a current file). I know I did that and Poser3 comes back to life - Till Poser4 Came along and killed it :). Your Friend Arye Guetta Hope I helped
Seriously? Wow, I'm going to go download Anthony Appleyard's utility on the FreeStuff right now. I have wondered what it was for.
One thing that has happened to me a few times is if I am running both Painter3D and Poser4 at the same time. And I edit a texture then swithch to poser to check and see how it looks. Poser will eventually lock up on me when I'm in the materials window. When I do a ctrl+alt+del. The figure says "can't find .obj". Even though it's really there. Deleting the .rsr in the geometries folder solves the problem. So I'm guessing this is an internal memory handeling problem in Poser. ScottA
I was having the same problem...this is what I did.... I copied...Into a folder I named Poser Bail.. asi32_12.dll Asifont.fon asifont.fon asifont.map Asiport.rsr imageioEngiWIN.dll imagieoUtilitiesWIN.dll MtsWriter.dll Poser.dta Poser.exe Poser.rsr unPoser4.isu I keep it seperate from where poser is installed,Then when crash rears it's ugly head...I go too my poser bail folder...select all of them...Then COPY them back into the main poser folder(The real one,ya know metacreations/poser4/etc..).I have never had to do A full re-install(knock on wood)ever...If this helps and/or works lemme know?????
heyas; i sent a p4 file (obj, cr2 and rsr-library file, not the obj rsr) to somebody with p3 to test, you know, make sure it would open okay in a previous version. well, the file started to open, said new version, blah blah, tried to open anyway, and then had an invalid page fault. it did that twice, and after the second time, poser 3 would NOT run. my guess is, the poser.rsr or even the exe got screwt. they tried copying those two files from the cd, but that didn't work. a full re-install is next. can a poser figure do that? i mean... does anybody know WHAT corrupts the poser.rsr; can it be files like this? also, somebody said you can write protect the poser.rsr file, right? instead of restoring it from backup all the time. i'll have to go through the cr2.... i didnt do anything fancy with the files, no transparencies or reflections. i did create ik chains with the heirarchy editor instead of in phi-build, though.... hmmm... any thoughts?
