Mon, Feb 17, 12:35 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: Importing Poser to Carrara (Transparency Maps)
wolfdd ( ) posted Wed, 08 March 2000 at 2:09 PM · edited Mon, 03 February 2025 at 3:51 PM
The last two days I spent a lot of time, trying to transfer characters from Poser to Carrara. Some problems, mostly concering texture maps I could solve, but the transparency maps drive me crazy... As far as I see this, Poser uses a variable transparency. Only this explains, how you do get real good looking hair with trans-maps. Carrara seems to know two states only, transparent or not transparent when using a map. RGB 0/0/0 or 255/255/255 of the map become transparent only. As a result of that the good looking hair from poser looks real bad in Carrara. I experimented a lot with the shaders to find a way out, yet without good results. Any ideas how to solve this problem? wolfdd
EdW ( ) posted Wed, 08 March 2000 at 2:29 PM
Hey wolfdd The only thing I have figured out was to use a layers list and put your trans map in the shader channel and a value in the opacity channel and mess with the value. I have gotten Allie's hair to look pretty good although I haven't tried any of the other trans mapped hair styles yet. Ed
wolfdd ( ) posted Thu, 09 March 2000 at 8:50 AM
Hi Ed, thanks for your hint. I will try that. I will loose some information of the poser original, but maybe it`s a good compromise. wolfdd
MASA ( ) posted Fri, 10 March 2000 at 10:16 AM
Hello wolfdd, Please see bellow. http://www.eurus.dti.ne.jp/~masasi/TIPS/CAP2.jpg This is Carrara texture's Room screen shot. I am Japanese. Sorry,My English is poor. MASA
wolfdd ( ) posted Fri, 10 March 2000 at 7:26 PM
Hi Masa, Thank you very much! This solution works perfect. wolfdd
MASA ( ) posted Fri, 10 March 2000 at 7:48 PM
Hi wolfdd, You're welcome. MASA
EdW ( ) posted Sat, 11 March 2000 at 7:18 AM
Hey Masa Thanks for the tip. It never occurred to me to use the trans maps like you did in your screen shot. Ed
MASA ( ) posted Sat, 11 March 2000 at 8:39 AM
Hi Ed, You're welcome. I had to work hard to find the way. I really thought... to transfer "KyokoHair" from Poser to Carrara. I am PoserFactory's member. Please visit my web site. http://www.eurus.dti.ne.jp/~masasi/ MASA
