Wed, Jan 15, 4:34 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
Subject: How do I convert a OBZ
SVicious ( ) posted Sun, 18 August 2002 at 6:25 PM ยท edited Wed, 15 January 2025 at 4:31 AM
I have pro pack and need to convert this obz file that I got from adding to my libary so it can be used in both pro and poser. Is there a converter out there to help me convert this file?
maclean ( ) posted Sun, 18 August 2002 at 6:46 PM
Just import it into poser using the menu. File/Import/Wavefront obj - (I can't remember how the menu reads but it's alt+f+i+w on the keyboard) Then size it to suit. mac
Little_Dragon ( ) posted Sun, 18 August 2002 at 6:54 PM
I did some experimenting. You can open the OBZ file with WinZip and extract the uncompressed OBJ file. Just give it the original filename extension (.obj) when WinZip asks. You can do the same for your CRZ file (compressed .cr2), also, if you haven't already.
maclean ( ) posted Sun, 18 August 2002 at 7:59 PM
OBZ? I thought it was a typo for OBJ. LOL What the smeg is an OBZ? (Hmm....I don't think I want to know this) mac
Little_Dragon ( ) posted Sun, 18 August 2002 at 8:22 PM
Pro Pack can optionally compress/uncompress its files on-the-fly, using the same lossless compression algorithms found in .zip archives. Since most Poser filetypes are text files, you can really shrink 'em down. The compressed files have filename extensions ending with a "Z" to indicate that they're compressed. Advantage? The files are smaller, so you have more room on your hard drive. Disadvantage? Poser 4 (without Pro Pack) can't read them directly. And Pro Pack has to uncompress them before it can use them, so it takes a bit longer to load something from the Library.
SVicious ( ) posted Sun, 18 August 2002 at 11:14 PM
Thanks I unzipped it into the obj format although it does bring a rather intersting question I have both the cr2, png, and obj in the same folder without me even having to put the obj into a gemoetry folder and it works fine will that work out for other users of the figure upon downloading it?
Little_Dragon ( ) posted Mon, 19 August 2002 at 11:36 PM
Other users will probably have to put the obj in the same folder that yours is in, since Pro Pack wrote the CR2 to specifically look for the obj in that folder. But you can edit the CR2 with a text editor (WordPad, EditPad, etc.) and change the folder names so that it looks elsewhere. Another solution is to embed the .obj in the CR2 itself, so that it doesn't need to look anywhere. But I haven't learned how that's done yet.
SVicious ( ) posted Tue, 20 August 2002 at 12:40 AM
thanks Little Dragon
