Sun, Dec 1, 6:03 PM CST
Subject: Help - I cannot make movies in Poser any more :( ???
khelben ( ) posted Sun, 18 August 2002 at 5:46 PM ยท edited Sun, 01 December 2024 at 5:40 PM
I tried to make a movie in Poser the other day and it would not work. Even a small 30 frame movie will not output at all. It creates an .avi file of 0 size and just spins the CPU. I previously was able to make movies just fine so I thought I might have to re-install Poser. I re-install and still no go. I am using Poser 4 with the 4.03 upgrade. I have Win2K, AMD 1900+, 512MB RAM. Anyone have any ideas? I'm desperate for help!!!
JerseyG ( ) posted Sun, 18 August 2002 at 5:51 PM
The same thing happened to me the otherday. Very much frustrated me. I creayed an animation. Put it into AVI. Went to watch the movie and nothing. Then I went to play the animation in poser 4 pro pack. I select the play button and nothing happens. I save the animation in poses, restarted poser and wala. Dont know what was up with that.
Bongo ( ) posted Sun, 18 August 2002 at 7:38 PM
Have you tried different codecs? When you go to make movie, do you have frames 1 thru 30 (or whatever) selected?
khelben ( ) posted Sun, 18 August 2002 at 9:07 PM
I can't select a different codec. I have "sequence type" being AVI or frames. I can output frames, but not the AVI. Yes, I do have frames 1 to 30 selected.
Bongo ( ) posted Mon, 19 August 2002 at 12:31 AM
try going to control panel, multimedia, devices, codec - see what's listed there. Have you recently installed new media players?
khelben ( ) posted Mon, 19 August 2002 at 8:00 AM
I don't have that in Win2K. I have Sounds And Multimedia, but it's only sound stuff. I recently installed Windows Media Player 7.1 and I still have 6.4 lying around. Sometimes I open a specific movie and it will go to 6.4, but most of the time it is 7.1. Perhaps that is a problem. I could try wiping media player out and starting fresh there. Would that be worth a shot?
Bongo ( ) posted Mon, 19 August 2002 at 9:42 AM
I don't have win2k, but it should be about the same, you have to CLICK on multimedia, then on that menu,Devices, then on that menu Video Compression Codecs. I think going back to your earlier player would be worth a try -
khelben ( ) posted Mon, 19 August 2002 at 10:21 AM
I have found my codecs list. First I uninstalled 7.1, but nothing changed. Then I removed DivX. Still nothing. So I put them back on. My codecs are: asus1 asus2 Cinepak DivX 5.0 Indeo Indeo 5.1 MS RLE MS Video 1 msh261 msh263 msyuv
