Bryce F.A.Q (Last Updated: 2024 Nov 08 7:02 am)
You will have to select both the cube and the cylinder and press the little "G" next to them to group them together.
Rudolf Herczog
Digital Artist
www.rochr.com
A week! Damn, that would persuade even me to read the manual! ;) As Rochr says, select both objects, after you've made one positive and the other negative. Click the Group icon, or choose object/group, and voila! Note that if one of the objects is already part of a group it don't work. The mat of the positive object is, obviously, the outside mat, and the mat of the negative object becomes the mat of the hole.
i'm trying to make a cube and spear it with a cylinder. cube is positive, cylinder is negative. then i want it to appear as a round hole right thru the cube, so i can see thru it. no matter what i do, it won't work. cannot find the group objects option anywhere, in bryce5. i 've linked the cylinder to parent cube and even made the cylinder transparent. nothing works. been trying every combination possible for about a week now.
