Mon, Feb 10, 5:41 PM CST
Subject: Daz's Morphos
Marque ( ) posted Sat, 24 August 2002 at 4:06 PM · edited Mon, 10 February 2025 at 5:36 PM
I'm really happy with this product, I've been playing around with it and I'm impressed that it creates faces so easily. This was done with one change. Marque
Bothellite ( ) posted Sat, 24 August 2002 at 4:16 PM
That's amazing stuff. I bought it and have had more fun with it than just about anything. This face/figure popped up and I applied some hair (crooked) and there you have it. I just keep using it and when a good possibility pops up I archive it for later. I'm embarrassed to admit that it's too easy to create great possibilities.
EricTorstenson ( ) posted Sat, 24 August 2002 at 6:44 PM
Can you get it to work without full body morphs? I am trying to strip those from my characters, and produce poses to do the same thing, but it is a time consuming task? How configurable is it (I really considered it, but just wasn't qutie convinced) eric
Jcleaver ( ) posted Sat, 24 August 2002 at 8:59 PM
You can uncheck the morphs you don't want affected. So if you only want the head to be affected, then uncheck the body. Works great!
queri ( ) posted Sat, 24 August 2002 at 10:26 PM
I don't have Pro Pack but I'm planning on ungrading to P5, would I be able to use this??-- these faces are great. Emily
queri ( ) posted Sat, 24 August 2002 at 10:27 PM
That would be upgrading not ungrading.
whbos ( ) posted Sat, 24 August 2002 at 10:46 PM
I can't get mine to work. I emailed DAZ, but the only thing they told me was I had to change the properties of one file so that it was not read only. This was for the PC only. I'm running Poser Pro Pack and when I try to make changes to the figure, it doesn't automatically update as it claims to do. When I click on the button to update the image, Poser locks up and I have to exit the program. I've tried this on two different machines: one with 256MB and one with 512MB RAM with similar results. Perhaps I've gotten a bad download file. Has anyone else had problems with Morphos on the PC?
Poser 2, 3, 4, 5, 6, 7, 8, 9, 10, Pro 2014, 11, 11 Pro
timoteo1 ( ) posted Sun, 25 August 2002 at 12:18 AM
Yes, I did and asked for a refund. I've bought just about every Python app that has been released ar DAZ and have been very hapy with it, but not Morphos. For one thing, I thought the updates would occur as you were using the sliders, in real-time. But also it is very unresponsive. It might appear to be locking up, but it's just responding VERY slowly. Just right click on the Python tab in your taskbar and select CLOSE. Poser should be okay after it closes. Mine also kept popping up with an annoying Python script window every time I would do something. Maybe our versions are corrupted. I often buy things from DAZ as soon as they are released, and they often email me with updates or notices saying the files were corrupted. So it's deinitely within the realm of possibility. Good luck!
pokeydots ( ) posted Sun, 25 August 2002 at 1:01 AM
Attached Link: Cyberbaby
Well I just got it tonight, and works good so far! I used it on the millenium baby, and turnde her into a cyber baby :) heres the thumbnail of the cyber baby, you can click the link if you want to see the whole image :) Didn't want to post the full size here as I just uploaded it to the gallery. Marque and Bothellite, great images! marque what hair did you use?
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
System Ram:  8GB
Bothellite ( ) posted Sun, 25 August 2002 at 3:57 PM
My copy started up like my late model 1952 Ferguson tractor... cough, cough, patooey. It finally started and works fine after telling me at one point that I needed the current/ version 8 of TCL (Tickle) server. I haven't messed with Tickle for a couple of years. Then I rebooted installing TCL and the darned thing ran fine. Go figure. I don't know but it's great now. Mines the second pix from the top.
kayjay97 ( ) posted Sun, 25 August 2002 at 4:33 PM
Well, I changed the read only file like I was told to and I still can't get it to work right. When I make changes it does not show them as you do it. I have to hit the create button to see what I did. So far I have gotten a good laugh at the mess I had made when I hit create but I still can't get it to work right.
In a world filled with causes for worry and anxiety...
we need the peace of God standing guard over our hearts and minds.
Jerry McCant
timoteo1 ( ) posted Sun, 25 August 2002 at 4:47 PM
Same here, Kayjay ... that's what I was saying before. The reason I didn't likeit was because it didn't show the changes as you do them (realtime). Is it supposed to do this?? Does it do this?
raven ( ) posted Sun, 25 August 2002 at 4:59 PM
You adjust the sliders to the maximum that you want those morphs applied, then you hit the create button. You should see the figure change to anything from slightly to a lot. Then if you adjust the Pose Level slider at the bottom, you can increase/decrease the effect of the character, which you should see in real time. Adjusting the individual body part sliders does not give you real time feedback, you have to hit the create button to see the change, and then play with the pose level slider to see a realtime increase/decrease of the effect. That's how it works on my Pro-Pack anyway.
timoteo1 ( ) posted Sun, 25 August 2002 at 5:05 PM
Thanks for the info Raven! I'll check that out. Unfortunately, it won't help with the unresponsiveness and script windows popping up all the time that I get. Looks like a call to DAZ tech support. Thanks again.
kayjay97 ( ) posted Sun, 25 August 2002 at 5:20 PM
Thanks Raven. I was under the impression though that you could see the changes as you moved the dial. I will play some more. Appreciate the feedback!
Jerry McCant
