Mon, Feb 10, 7:27 PM CST
Subject: DAZ's Mimic for Mac Problem Help
petereed ( ) posted Sat, 24 August 2002 at 9:38 PM · edited Sat, 08 February 2025 at 10:24 AM
I just got Mimic for Mac from DAZ and it won't launch. When I double click to open the app there's a quick flash of something in a small dialog box in the middle of the screen then it shuts down. I have Carbon Lib 1.5, I rebuilt the desktop, rebooted and no luck. There's is no manual for this thing...no tutorial or info at DAZ.com...Lipsinc.com is down. Can't find any help using Google. I'm pretty po'd with DAZ at the moment. I know I'm not the only Mac user experiencing problems. Any help would be appreciated. If someone has the fix, this may be the first and only place where a MAC Addict can get help with this. Until there is an answer, Mac users email DAZ and get an answer before buying. I'm going off to lick my wounds (^#$*&^%$#!@!!!!!!!!
Little_Dragon ( ) posted Sat, 24 August 2002 at 9:43 PM
Try asking wolf359, if he doesn't notice this thread himself. He beta'd the Mac version, and I know he made it work, since he posted animations afterwards.
tjs61822 ( ) posted Sat, 24 August 2002 at 11:34 PM
It works fine on my G4-867 / MacOS 9.2.
mateo_sancarlos ( ) posted Sun, 25 August 2002 at 12:13 AM
Mimic works for me, too. You might have directory damage, where Mimic is looking for a file on start-up and not finding it even though it's there. You could tell if you ran MacsBug or maybe the terminal in OSX. DiskWarrior will usually fix problems like that (OS 9.x), but rebuilding the desktop, zapping PRAM, or reinstalling apps is usually a big waste of time when the real problem is directory damage. If Windows had an app like DiskWarrior, you wouldn't hear about all these weekly "hard-drive crashes" they get.
jjsemp ( ) posted Sun, 25 August 2002 at 1:04 AM
Are you keeping the CD rom in the drive? You have to keep the CD in the drive because Mimic needs to access it to get past the copy protection scheme.
bikermouse ( ) posted Sun, 25 August 2002 at 5:20 AM
Peter, As jjsemp says I think the Mimic CD rom needs to be accessable at startup as that is the antipirate trick they use - at least that's what I read a few months ago. BTW L.D. I broke down and got Mimic It'll probably be a couple of weeks before I get it but . . . - TJ
petereed ( ) posted Sun, 25 August 2002 at 7:38 AM
Thanks to everyone for their replies. I have the CD in the drive from startup. Will Norton Disk Doctor fix this kind of problem with directory damage, assuming that is the problem? I don't have DiscWarrior and Norton's Doc takes forever to run. I'd probably get a reply before it goes through it's paces. This is SOOOOOOOOO FRUSTRATING! BUT thanks again to everyone...
wolf359 ( ) posted Sun, 25 August 2002 at 7:42 AM
Its working fine for me even in OSX now if i could just get my OSX seat Of poser 5 Ill be Complete :-)
My website
petereed ( ) posted Sun, 25 August 2002 at 7:49 AM
Well I'm glad it's working for you. I want my money back!!!
xvcoffee ( ) posted Sun, 25 August 2002 at 9:33 AM
NO!!!! Is that one less animator?!!
scaramouche ( ) posted Sun, 25 August 2002 at 10:14 AM
My students beta'd the Mac product, and it works fine in OS 9, 9.1, 9.2, 9.2.2, 10.1, and 10.1.2. Make sure that you do not exceed the 64-character path limit. The best way to install MacMimic is to put it on the highest directory level - not the Desktop, but in the main Macintosh HD folder, e.g., Macintosh HD:Mimic It is also best to do the same thing with your Poser install. And I think you already know that you have to keep the CD in at all times. No, it does not work with either Virtual PC v3 or v4. One last item - make sure you are using the latest CarbonLib extension. -scara
tjs61822 ( ) posted Sun, 25 August 2002 at 11:19 AM
The CD needs to be in when using Mimic? Mine works fine without it.
petereed ( ) posted Sun, 25 August 2002 at 3:39 PM
Thanks to all those WHO HAD helpful advice. I finally got it to open. For anyone else who may have the same problem. Here was the fix for me...Norton Utilities...ran the Disk Doctor. It gave a report that the bit bundle for MIMIC was off and should be on. Then it fixed that with the "click the FIX button". After that, although I already had "rebuilt the desktop", I recalled that Conflict Catcher also has a "rebuild the desktop" function. So I opened CC and clicked on rebuil the desktop, again. Then I tried opening MIMIC and it finally worked. I recorded a few lines with Toast's Spin Doctor, which made an aiff file and it worked. Now I'm playing around with tweaking the animation. The Mimic version of my aiff has that restricted wired jaw look that Mimic gives. But, at least it can be tweaked. Thanks again for the HELPFUL comments.
xvcoffee ( ) posted Sun, 25 August 2002 at 11:07 PM
Yes, Norton Utilities may take a long time to run but it's the best way out when someone says it's directory damage.
