Fri, Jan 31, 7:54 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 3:43 am)
Subject: Question about Stephanie model from Daz 3D
gsalas ( ) posted Tue, 27 August 2002 at 12:55 AM · edited Fri, 31 January 2025 at 7:53 AM
I know that the body is the same geomentry with a ton of new morphs, but is the head? IE, it the stephany head, a morph from the original victoria head, or is it a compleetly diferant geometry, with diferant number of verticals? Thanks -Gabe-
Kagato98 ( ) posted Tue, 27 August 2002 at 1:02 AM
From what I understand, Stephanie is Michaels mesh rearranged a whole lot. So if your asking if it's the same geometry as Victoria's head, I highly doubt it :) . I think some of the morphs that Michael uses for the head would work, but I wouldn't wanna see the results :)
gsalas ( ) posted Tue, 27 August 2002 at 1:31 AM
So than victoria say chest morphs wont work on stephany then? By the way, if you are right, then stephany is a mike transexual??? Oh my... -Gabe-
DelicateCrystalRose ( ) posted Tue, 27 August 2002 at 4:06 AM
Stephanie is made from Michaels mesh and the way I understand it the Vicky chest morphs would not work on her
kawecki ( ) posted Tue, 27 August 2002 at 4:27 AM
On the other side, maybe Stephy chest morphs would work with Mike............... !!!!!
Stupidity also evolves!
creativechaos ( ) posted Tue, 27 August 2002 at 4:54 AM
Actually, the myth remains a mystery...I've had a little bit of success using The Tailor to transfer morphs from Vicki to Stephanie...but when used to extremes the mesh becomes a bit crumpled. Most of the FBM's don't transfer right...haven't tried from Mike to Steph yet, but with a program like Tailor, it might just work shrug
My Store              My Gallery
Remember...getting lost is the senic route to the eventual destination. (And a lot prettier than the straight road)
shadowcat ( ) posted Tue, 27 August 2002 at 5:34 AM
Oh no, quick, somebody get that man a bra! some morphs can be transferred between Mike & Steph, including the breast morphs. Head morphs are out because Daz modified the upper eyebrow when they made Steph & hip morphs are out for obvious reasons.
JDexter ( ) posted Tue, 27 August 2002 at 7:02 AM
Actually I transferred the Boris (Available in the Marketplace here) morphs to Stephanie with no problems. It opened up a lot of options for her and I am able to get looks I was not able to get before. Stephanie does take Michael head morph very nicely. If I was at home at the moment I would attach on of the hybrid faces I have been using. JDexter
shadowcat ( ) posted Tue, 27 August 2002 at 8:46 AM
oh, didn't relize that. I knew they reworked the brow so I figured they wouldn't tranfer. Hmmmmm...... need to take a closer look into those morph then.
JDexter ( ) posted Tue, 27 August 2002 at 9:21 AM
As a matter of fact, I specifically wanted some of those morphs for the brow, and they worked beautifully. The problem I was having was my lady was looking a little cranky. I was able to reshape with those morphs, now she looks like I wanted her to look. JDexter
jelisa ( ) posted Tue, 27 August 2002 at 10:24 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=170433
I also transfered head morphs from Michael to Stephanie. I used the Orc character for Michael and transfered the morphs using Morph Manager. http://www.renderosity.com/viewed.ez?galleryid=170433 http://www.renderosity.com/viewed.ez?galleryid=170436 Got another version up at my site as well. http://www.fignations.com/jelisa/dbryce/img130.html Head morphs can be transfered from Michael to Stephanie, but not setting the dials all the way to 1 helps to soften the morphs for her. -darlisa
gsalas ( ) posted Tue, 27 August 2002 at 12:05 PM
Hi all, I guess this strand went a bit futher ary than I was expecting. serpentis , You refered to "using The Tailor to transfer morphs from Vicki to Stephanie" What it "the Tailor". I have not heard of it, and that may solve my question. -Gabe-
LeeEvans ( ) posted Tue, 27 August 2002 at 12:35 PM
Attached Link: http://www.daz3d.com
Gabe.. the Tailor is a morph utility for sale at DAZ3D that is supposed to be used for "copying" morphs from a figure to clothing... so that the muscle morphs in M2 can be transfered to Mike's clothing, etc.... But evidently it work for creating morphs in other figures as well.. :) -Lee
RHaseltine ( ) posted Tue, 27 August 2002 at 1:02 PM
For transferring morphs you use Morph Manager (in Freestuff) to put in a copy the actual offset (delta) values - the Tailor adjusts one mesh to follow the morph of another to which it conforms (clothing), or matches (as with Steph to Vic, same basic body and joint parameters.)
Jaager ( ) posted Tue, 27 August 2002 at 2:06 PM
Using the wrong verbs can confuse what is going on. The Tailor will 'translate' morphs between different geometries - if the groups line up. It is not a cut-n-paste operation. Transferring/copying morphs only works if the groups of the two files are identical. This is cut-n-paste. In most cases copying works between Mike:Steph - not hip - but since the geometries start from different places, the differences produced by the morphs may not look good. Vic:Kids is the same situation.
gsalas ( ) posted Tue, 27 August 2002 at 6:18 PM
Thank you, that helps because I am trying to speach in english, where it is not my first language. I have dificulty with "Verbs" and "Ajitives" So you would up snsering my quirie. -Gabriel
