mon1alpha a majority of the time that error message is for one of two reasons... 1) a corrupted geometry RSR (solution: delete the corresponding geometry rsr & poser will automatically build a new one) or 2) a misplaced geometry file (solution: open the cr2 in a text editor & move the corresponding file to the proper location or edit the cr2 to point to the geometry file in the new location.
IMO deleting rsr files should be done one at a time, as problems occur. A well-intentioned DAZ tech once recommended that you delete ALL of them from Geometries, claiming "you don't need them." I did that...disasterous results, and I had to reinstall the app. I'm not as technically astute on this issue as others, but from experience, think you should only do it with specific rsr files that cause this error. 320MB RAM is not insufficient memory. :-)
Thanks for all the concern and help but too late. I have deleted a lot of rsr files and apart from the default dork having a variety of hair colours each time I use the big P there's no apparent problems. I deleted pretty well all rsrs from geometries folder. If the program goes belly up I'll re-install but as yet it's ok.........(ominous music plays in the background) Mon the eternal optimist
No, it's not senility but an annoying intermitent error message 'you have run out of memory,save now and exit etc...' It happened when I tried to open a bat lab freebie which I'd used before, also happened with Panzergen clothing and some Iso clothing. I've got 320mb ram...Help and suggestions please Thanks for your time Mon
