If you're going to do textures and surfaces, you really need to have some kind of paint program. One other method that might work: Use a Ball prop; set its Y scale small to make it almost flat. Set its color to violet. Place it inside the character's skin at the point where you want a bruise.
My python page
My ShareCG freebies
Attached Link: http://www.fignations.com/jelisa/fignations/textures/reference1.html
I have some photos of bruises on my site, the result of an accident I had in July 2001 where I totaled my car. The textures can be used as is or as references for making your own. -darlisaThank you all for the support,probably mistake was caused english is not my language....so,with "bruises" I intend the flexed skin under the pressure of something,for example a finger that push a single,little point on a body(cheek,abdomen,or another flexible body part)or also the effect of a stomping on the bed! This was the cause I don't understood the Photoshop reply... Probably,I need some kind of magnet,but I don't know if I need some particular magnet or if I've to modify in some way a pre-existent magnet(I never try this procedure),or if there's another way!! I apologize for my not clear question. P.S:I find usefull your link jelisa(I use an essential corel photo for my textures).
For a small impression I guess you could use a bump map. But for larger ones and for props like beds you should probably use magnets. Select the part of the character or prop you want to change, open the Object menu, and click Create Magnet. Then read the manual and any tutorials you can find. Prepare yourself for a grueling experience.
Attached Link: http://www.morphworld30.com/tutor.html
Have a look at Traveler's MorphWorld for some magnet tutorials. Here is a link to the tutorial page.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
How to do bruises in specified section of the characters(people or walls or others)? There's a (simply-->I'm not an expert) procedure for do it? Bruises like finger pressure on cheeks or fist crushed stomach or similar... Thank you!
