Thu, Nov 14, 2:10 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Texture Bug in Carrara?
wolfdd ( ) posted Wed, 15 March 2000 at 1:10 PM · edited Thu, 14 November 2024 at 2:02 PM
Hi, I imported a mesh from a 3DS file. This mesh represents a landscape and has 21,000 facets. I apply a flat mapping shader with a colour texture. It is shown properly in prewiev window. When I switch back to Assemble window the CPU use goes up to 100%. From now on I have a total slow down in Carrara. Every action, no matter what function or menu option I chose, takes 2 - 3 seconds until I get a reaction. Even when I close the scene and choose 'Open' or 'New' this slow down goes on. I tried texture maps in different sizes, different shader setups, no change. I could reproduce this effect with different objects. When the facet count is more than around 10,000 I have this slowdown. When I use these objects in other 3D software, there are no problems. On the other hand I worked with textured objects from poser, where the counter showed over 40,000 facets for the object and over 120,000 for the whole scene without problems. I am using Carrara 1.01 on a P III 500, 256 MB RAM with Windows 2000. Is this a known bug in Carrara? Any help is appreciated. wolfdd
ClintH ( ) posted Wed, 15 March 2000 at 2:12 PM
wolfdd, Have you tried Importing the .3DS file into Carrara and then Exporting it as OBJ? Then Import this OBJ. .3DS files might slow Carrara down. Most of the Poser items/figures, if not all, are OBJ format. Just a thought. Out of habit I convert all my .3DS files to OBJ. Clint
Clint Hawkins
(Zakk Wylde (2007))
wolfdd ( ) posted Thu, 16 March 2000 at 9:09 AM
Thanks. This idea was worth a try, but there was no change. I also converted it to .OBJ, using another program. The result was the same. After i use any texture map, Carrara slows down and nothing can stop this. I have to exit Carrara and start it again to have the normal speed again. I love to work with Carrara, but this bug really bores me... wolfdd
