Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 9:07 am)
Okay, after you've resized the prop and positioned it on Posette's ankle, go to the Object menu and select "Change Parent". A dialog box will pop up which lists every element in the scene. Scroll down until you find the body part to which you want to attach the torus; for an anklet, you'd probably want to parent to the right or left shin, although one of the feet might be a possibility. Anyway, select the proper body part from that list, then click OK. The torus is now attached to the figure, and will move along when the body is posed.
Hey uhm how can I make or where can I find an anklet or ankle bracelet for the p4 woman. It should only be simple and not joe's thing. thanks for any help
