Tue, Nov 26, 8:23 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: Question about jpeg as background.
SophiaDeer ( ) posted Sat, 31 August 2002 at 12:15 PM ยท edited Tue, 26 November 2024 at 6:25 AM
Hello,
I have another silly question but this is driving me nuts.
I have a large background jpg, 1000x1200. It is very crisp and clear when I view it through PSP and Photoshop.
When I use it as a background in Poser, even when I make the render smaller than the actual jpg. size, the quality is very poor.
I have the resolution set at 300 and it still is inferior quality.
Any suggestions would be most appreciated, please.
Thank you in advance.
Warm Regards,
Nancy Deer With Horns (SophiaDeer)
Deer With Horns Native American Indian Site
sirkrite ( ) posted Sat, 31 August 2002 at 12:30 PM
Use a one sided square and enlarge it to just cover your background area, and then apply your jpg as a texture to it. That will give you a much better background when rendered.
SophiaDeer ( ) posted Sat, 31 August 2002 at 12:33 PM
Thank you very much Sirkrite..I will try that. Warm Regards, Nancy
queri ( ) posted Sat, 31 August 2002 at 3:29 PM
Attached Link: http://www.digitalskinz.com/tutorials/poserBckgrnd.htm
Sometimes the lighting will interfere even with the jpeg on a square workaround. If you have a paint program that utilises layers and alpha channels-- I believe PSP does, I use PS, and you are only using one figure, you can render agianst black and use your background in your paint program, it is absolutely the clearest crispest way to do it. I'm a real dummy about alpha channels but even I could understand this tutorial. Emily
SophiaDeer ( ) posted Sat, 31 August 2002 at 4:19 PM
Thank you very much, Emily..this is very helpful! Warm Regards, Nancy
Little_Dragon ( ) posted Sat, 31 August 2002 at 4:39 PM
You can solve any lighting problem on the square by setting the Object, Highlight, and Reflection Colours to pure black (RGB 0,0,0), and the Ambient Colour to pure white (RGB 255,255,255). This will override/wash out all lighting, even coloured lighting. Also, disable shadows on the square prop to prevent it from casting unwanted shadows on the rest of your scene.
SophiaDeer ( ) posted Sat, 31 August 2002 at 5:59 PM
Thank you Little Dragon..that is very helpful too. Warm Regards, Nancy
Bongo ( ) posted Sat, 31 August 2002 at 7:20 PM
I think it helps when you use a pic as background, to make the pic the EXACT size (not just ratio) of the final render. So if final render is 300 x 200 use a 300 x 200 pic, not a 600 x 400. Less conversion to make.
SophiaDeer ( ) posted Sat, 31 August 2002 at 7:42 PM
Ahh thank you for that good piece of advise, Bongo! Warm Regards, Nancy
