Mon, Jan 27, 9:12 AM CST
Forum Moderators: Staff
Subject: Technical question!
Metrini ( ) posted Sat, 31 August 2002 at 5:21 PM · edited Mon, 27 January 2025 at 9:11 AM
Does anyone know if there is a limit as to how many folders I can have in the POSE option for example. Is it 250 or 255?? I was doing an experiment and realised I couldnt read the folders after 256 Any ideas?
lesbentley ( ) posted Sat, 31 August 2002 at 8:29 PM
I quote Hogwarden: "You will start to run into problems when you get to having more than 256 subfolders in any library folder... Then Poser will start to truncate the names, or load the files incorrectly."
Metrini ( ) posted Sun, 01 September 2002 at 6:39 AM
is there a solution to that problem??
lesbentley ( ) posted Sun, 01 September 2002 at 6:16 PM
Hogwarden has a utility called "PBoost" That addresses that problem, I think it's available here in the store. I don't have it myself, but the comments I have heard are generally quite favourable.
lesbentley ( ) posted Sun, 01 September 2002 at 6:27 PM
Sorry that should have read "PBooost" (with 3 o's).
Metrini ( ) posted Mon, 02 September 2002 at 11:53 AM
woot thanks!
