Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
You can never have enough computing power, but that machine should be fine. Until recently I was using a PII-366 with 256meg and a iMac 233 with 192meg for most of my Carrara development work. It's not fast, but you won't suffer any reduced functionality. Good luck, Eric Winemiller Digital Carvers Guild Freeware and commercial 3D extensions http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
As far as your "can't use booleans... greyed out" goes... Sounds to me like you either; Are in the main assembly room and are attempting to boolean and only have selected ONE object or perhaps you have selected a grouped object. Create a scene with 2 spheres and have them intersect. Using CTRL, select both spheres and then you will see the boolean choices are available. Or; You are in the vertex modeling room and are trying to do a boolean subtract, and boolean subtract is 'greyed' out. You need to SELECT ALL in the vertex modeling room and then hold CTRL + ALT... while holding CTRL + ALT click on a vertice of the object which you wish to REMAIN, it will then turn yellow(the vertice).... You will now find that boolean subtract is not greyed out anymore. ****** A word about booleans..... Don't use them if you don't have to.
I am a very unique person... Just like everyone else
Thanks to all! Etchasketch cracked the code on my boolean problem. I had a secondary the same night I posted the query: I could not select a shape in the Vertex Modeling window. I kept getting a message that said "An unknown error has occurred..." I was thinking that mayhap my polygon count was too high [tho' the model was barely started]for the resources computing them. As it turned out, that problem went away when I re-launched the doc. in the morning. Thanks again.
Bought Carrara 1.1. Had all sorts of problems. Upgraded to 2.0 thinking that they would be fixed. Not so. Can't use Booleans, for instance. The menu selections are greyed out. I'm using a Packard Bell 333Mhz Celeron/250Mb RAM. Is this system just too much of a wheezer for Carrara?
