Nope, she works fine with ProPack, you will need a lot of ram though, I'm running with 512mb & it can be very slow loading Vicky & posing her. Just make sure you have either the latest version of Poser 4 (4.03), or you get the patch from Curiouslabs, and the latest patch for ProPack. I can't help you with the lightwave question but ProPack does ask if you want to install the lightwave plug in during installation. Unfortunately I don't have lightwave. You could try the lightwave forum, someone there may know
Thanks for the reply idolitry. And for Tirjasdyn... good question...I dunno what to do. I am a little bit confused here. I obviously would like the best version for my dollar, which I would assume would be Vicky 2. But; when I went to the Daz website, I see that Victoria 1.0 is $69.00 and Victoria 2.0 is $59.00. I was kinda thinking that you need a preliminary installation of Vict. 1 and then have to purchase Vict. 2 as an upgrade, but maybe I'm wrong about this? I'm really confused about the different options here, and to add insult to injury there is the "millenium collection", which I assume is something else again. What do you recommend? For system configuration I am running a P4 1.5 GHZ with Windows 2000 and 1GB RDram. Thanks guys...
I had the same choice to make when I first bought Vicky, option No1, or option No2. In the end I went for Vicky 2, from reading messages posted here by other members Victoria 2.0 (to give her her posh name) has more morph options & is generally better to use. You don't need a preliminary installation of Vicky 1 to install Vicky 2 (unless you plan to go via the upgrade path). I'm running a P3 500 mh with win98. With your spec you should have little trouble running anything you buy for poser. A lot of people hereabouts reccommend as much ram as you can cram in, poser uses lots when rendering (if you plan to render in poser & not lightwave, I don't know how ram intensive that is when rendering). People hereabouts are very friendly, if you need more advice just hollar!!
I'm pretty new to Poserland, and notice that Victoria is the standard in female figures. The realism is awesome, and I would like to order the CD but am curious as to whether there are problems associated with using her with Propack. I plan to open animations with her in Lightwave. Anybody know if this works? I did a search and didn't get any results. Thanks...
