Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 5:17 am)
Boni, ah yes, that is a good point...but does anyone know which one I should choose so the mats appear correctly.....mine don't seem to want to work...Sharen PS; I know this isn't about the dragon, but let's pretend it does, since I am pretty sure this is going to happen to me with the dragon when I get the full version...
I have another question regarding LE's of any kind. Is it possible to add morphs to the LEs? Since it's a millenium character and morph mover programs suggest that there are morphs that can be moved from other Mil folk, yet the resulting cr2 doesn't seem to take any of the morphs. Is there some kind of lock that prevents this?
barbarelly, yes you can add morphs to the LE versions. But the morphs must be designed for the .obj that the .cr2 uses. For example you can't transfer vicky morphs to michael, but you CAN transfer morphs from vicky to the mil kids because they use the same base .obj Characters that match: Vicky - Vicky2 - MilGirls - MilBoys - MilBaby Mike - Mike2 - Steph - Aiko VickyLoRes - VickyLoRes2
Ummm, what textures for the gorilla, the only Mats I have are 1 for changing the gorilla to white (all white), 1 for the texture (all map) and the rest are just for changing tones, the tone change pz2 don't have any texture info in them, just color changes. Course I didn't download the Full gorilla, I got the LE then purchased the morphs and maps for it. Might wanna check the pz2 and see if the 0 0 are there after the texture lines.. eg. textureMap ":DAZ:Animals:GorillaHeadM.jpg" 0 0 bumpMap ":DAZ:Animals:GorillaHeadB.jpg" 0 0 Don't remember if I had to change them or not to have them work, but wouldn't be the first time have had to make the correction. Sorry so long winded, but hope this helps.
Consider me insane if you wish, but is your reality any better?
Okay, all remember when the gorilla came out, I am assuming it is the same thing....question, when you download the LE version, you have limited articulate parts....Correct, then when you buy the full blown version you now have them all....my second question, with the Gorilla LE, I downloaded the freebie, then I bought the full version, now I have 2 gorillas I can use, but why keep the first one if it is so limited? Not to be a bother but the full version of the Gorilla doesn't take his texture maps at all, I have to use the old fashion way to get the textures on him, do you think it is cause it is clashing with the LE version.....? Sharen
