Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Dec 21 2:40 am)
btw this is 2 (identical) wall panels 1 door panel and 12 of the little addon props thrown in at random, some repeated (all addon props are double sided) the 2 lights in the middle of the wall and the little datapanel are the same prop.... only the datapanel one has ben rotated 180 degrees so essentially all panels and props are 2 props in one........... Double for you money : )
Thanks for posting an update on the conversion, chem! The look absolutely stunning so far. :o) I'll rework all the UVMaps on the "Massacre Texture Pack" as per your instructions. Yes, I will remember to paint inside the lines... yes, I will try and keep the modules seamless. LOL! I'm learning a lot from you and having immense tons of fun in the process. - M
Mind Over Matter
"If you don't mind, then it don't matter."
Attached Link: Massacre
Completed the modeling (over 80 unique, some reversible, objects) and most of the texturing (3 different texture themes). Getting ready to send this off for conversion into a Poser prop. This render was done in LightWave, but all the textures are medium resolution seamless tiles (600 x 600) created in Photoshop. Will have some Poser test renders coming out soon.I've gotten some positive feedback and encouragement, and lots of suggestions for future additions... hope I don't miss anything else. Any other suggestions? Thanks for your time. :o) - M
Mind Over Matter
