Fri, Jan 10, 12:51 AM CST
Subject: Poser 4 animations in Bryce 5?
Sydney_Andrews ( ) posted Fri, 06 September 2002 at 3:36 PM · edited Fri, 10 January 2025 at 12:42 AM
Hi, once I import and texture Victoria into Bryce from Poser, is there a way I can animate her? Is it possible to animate her in Poser and the export the file from Poser to Bryce? Is what Im asking making sense? Thanks
krimpr ( ) posted Fri, 06 September 2002 at 4:05 PM
Hello echo;
There are two inexpensive programs to the best of my knowledge (under $50.00 each) which will allow you import animations made in Poser into Bryce. They are both downloadable, and require you to create the actual animated sequence inside poser with your Victoria figure (or any other Poser character) and then essentially this software transports your animated characters into your Bryce scene. The first one is called "Natural Pose 2.0" by Conan (A free demo is available for download) and the other one is called "Susanna". Unfortunately, Bryce does not import Poser animations alone, but with one of the above choices, you can.
EricofSD ( ) posted Fri, 06 September 2002 at 7:25 PM
And from what i understand, Conan's program helps out with the texture import problems that can be associated with Poser transmaps from time to time. Krimpr is right, you have to animate in Poser and bring the animation into Bryce. Bryce won't let you animate a human model. The other way to go is to animate your sky and background scene in Bryce and bring that into Poser as an animated backdrop. Unfortunately, there's no easy way to combine both programs. you might also want to look into Vue d'esprit with the new Mover add on as well.
Aldaron ( ) posted Fri, 06 September 2002 at 9:31 PM
Attached Link: http://dawnstarproductions.50megs.com
Not to toot my own horn but if you don't have the money for the above programs you can do it manually, warning it can be a pain. Tutorial at the above link.
bikermouse ( ) posted Fri, 06 September 2002 at 9:48 PM
Aldaron, Ah, you finished the tutorial. Great! Gonna study this one. - TJ
joke ( ) posted Sat, 07 September 2002 at 6:44 AM
Attached Link: http://www.datamike.com/susu.htm
Susanna link is www.datamike.com/susu.htm Another program that can be used to combine Poser with Bryce is Nuutti www.datamike.com/susu.htm
