Hello echo;
There are two inexpensive programs to the best of my knowledge (under $50.00 each) which will allow you import animations made in Poser into Bryce. They are both downloadable, and require you to create the actual animated sequence inside poser with your Victoria figure (or any other Poser character) and then essentially this software transports your animated characters into your Bryce scene. The first one is called "Natural Pose 2.0" by Conan (A free demo is available for download) and the other one is called "Susanna". Unfortunately, Bryce does not import Poser animations alone, but with one of the above choices, you can.
And from what i understand, Conan's program helps out with the texture import problems that can be associated with Poser transmaps from time to time. Krimpr is right, you have to animate in Poser and bring the animation into Bryce. Bryce won't let you animate a human model. The other way to go is to animate your sky and background scene in Bryce and bring that into Poser as an animated backdrop. Unfortunately, there's no easy way to combine both programs. you might also want to look into Vue d'esprit with the new Mover add on as well.
Attached Link: http://dawnstarproductions.50megs.com
Not to toot my own horn but if you don't have the money for the above programs you can do it manually, warning it can be a pain. Tutorial at the above link.Attached Link: http://www.datamike.com/susu.htm
Susanna link is www.datamike.com/susu.htm Another program that can be used to combine Poser with Bryce is Nuutti www.datamike.com/susu.htmThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi, once I import and texture Victoria into Bryce from Poser, is there a way I can animate her? Is it possible to animate her in Poser and the export the file from Poser to Bryce? Is what Im asking making sense? Thanks
