Sun, Nov 24, 12:23 AM CST
Subject: DEM's and bryce5
grissle ( ) posted Thu, 05 September 2002 at 7:16 AM · edited Sat, 23 November 2024 at 10:37 PM
hi all , does anyone know if its possible to import DEM's direct from microdem into bryce5 or is there a program available that would allow me to do this?I know macdem does something similar for mac uses via photoshop and .raw files any suggestions ?
Patrick_210 ( ) posted Thu, 05 September 2002 at 3:47 PM
DEM is a supported file format under "import object".
EricofSD ( ) posted Thu, 05 September 2002 at 9:42 PM
Attached Link: http://www.annsartgallery.com/tutdem.html
I have a tut up on using the .gz files from USGS. I found the file rename trick to work just fine for those. Brycetech has one also.
grissle ( ) posted Fri, 06 September 2002 at 6:05 AM
thanks you two, the import dem wouldnot work for me ,but then the tutorial pointed out where i was going wrong ,nice joint effort!
Erlik ( ) posted Sat, 07 September 2002 at 5:27 PM
Eric, for some reason, renaming the gz files to dem didn't work for me. But extracting them with WinZip and then adding the dem extension worked allright.
-- erlik
