Sun, Nov 24, 1:33 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Programs keeps locking up...
MindsEyes ( ) posted Mon, 09 September 2002 at 10:20 AM · edited Sun, 24 November 2024 at 1:22 AM
Hi. I was wondering if someone has any idea's on how to fix this. I just downloaded the milenium dragon from daz3d, along with the poses. When i open poser, and try to open the character to start "playing", poser freezes, and i have to control|alt|delte it, because it does not respond. Why does it do this? I have had this problem once before with a prop from the free stuff section, but i deleted the prop. I would like to keep the dragon, cause it looks cool. I even tried to hand move each file, to see if that would help, but it didn't. Normally, poser never gives me any problems. Is there someone who can help? Thanks, M.E.
Cage ( ) posted Mon, 09 September 2002 at 1:39 PM
Several people seem to have reported this problem. The best solution seems to be to reduce all of the textures to 50% or less in a graphics editing program, particularly the bump maps. If the problem persists, you might try deleting the Geometries .rsr for the dragon....
MindsEyes ( ) posted Mon, 09 September 2002 at 10:42 PM
can u explain how to reduce the textures? i never have time to sit and exploit poser to its fullest when i use it. i just use it. thanks for the reply.
Cage ( ) posted Tue, 10 September 2002 at 5:21 AM
Using your preferred paint program, open the texture files you are using for the dragon. Select each one in turn and resize the image to 50%, or whatever size you prefer. Save the altered files with a new name, so as to preserve your original textures. Once you have done this, open the dragon again in Poser and change the texture settings to point to your new files. If you are using Poser 4 you will have to re-create the .bum files.
MindsEyes ( ) posted Tue, 10 September 2002 at 9:49 AM
okay thanks. i got it. finally it loadd. now when i click on it, to resize the figure itself, i get an exceptional error. LoL. guess im not supposed to use it. :o). I'll keep trying. Anyway, thanks for the help.
